Digital I/O
DIG_DB_Transfer() & DIG_Block_Check()
Is the DIG_Block_Check() has a different functionality with the DIO 6534 than with the DIO 6533? I am using double buffering and external source to trigger,pattern generation, ni 6534 and CVI,NT. I am using DIG_Block_In and the half buffer transfer to keep cycling the buffer and I don't want it to stop until the user uses clicks a button to stop and I call DIG_Block_Clear(). I want to use DIG_Block_Check() to check for erros but not to halt the double buff operation. Is this possible?
(5,327 Views)
Yes. What you described will work just fine. DIG_Block_Check() never halts the operation, it will only be halted by either an error or a call to DIG_Block_Clear().
(5,326 Views)
