01-23-2003 03:14 PM
01-24-2003 01:08 PM
01-24-2003 03:39 PM
01-31-2003 08:12 AM
12-16-2013 06:59 PM
@Spencer S. wrote:
The digital port on your board can not be timed by external or internal hardware. Software-timed means that you must make a software call each time you want to read or write from the digital port. Thus, your digital operations will be performed as fast as your software executes.
Spencer S.
I have the same question that we cannot use external or hardware clock to drive the DIO port but what about counter port? Can I use external clock to change the sample rate instead of using software-based clock? If so, which pin I should connect the clock to ?
