Digital I/O
DAQCard-6533 Connections
I have a DAQCard-6533 with the following cables and connector box. Is this a valid configuration? I am having difficulty reading the inputs.
1835698-01 .1 meter cable, adapter from the card to:
183432B-02 2 meter cable
CB-68LP connector box
(3,505 Views)
Hi buckeye -
     The 183432B-02 cable, CB-68LP connector box and DAQCard-6533 are all compatible.
     I am a little unclear on what the 1835968-01 is.  Can you double-check that part number and provide a description of what it is?  I can't seem to find it in our parts catalog.
     Thanks!
Gary P.
(3,492 Views)
Accepted by topic author buckeye80
It appears to be similar to a cable with part number, PSHR68-68M.
I believe that I got through this. Pin 1 of the connector to the PCCard was not marked. Unfortunately, it fits in the card both ways and I had it reversed (upside down). I found this out by injecting +5v signal and looking at the response via the Measurement and Automation utility.
Thanks, for your help!
Go Bucks!
(3,489 Views)
