01-09-2015 12:12 AM
Why is the 50-pin I/O in my 6014 DAQ not working? please help guys
when I use the analog channels available on my signal accessory, it works. however, if I use the analog channels on the 50-pin MIO, it does not work at all.
do i need to enable it or what?
01-12-2015 01:04 PM
Hi jerlim,
What is your exact setup? And what exactly are you trying to do? You shouldn't need to specifically enable it.
01-12-2015 04:56 PM
sir, thanks for the reply.
just want to be sure. i am using this board:
i want to utilize as much analog and digital IO pins. however, it does not work when i use the 50-pin whether NRSE or Differential. it only works when i use the quick connect for analog. in that case, i would be limited to only 2 analog inputs and no digital IO since there are no quick connects for digital IO.
thanks
01-12-2015 06:05 PM
01-12-2015 06:42 PM
ooh.sorry.i'm still new. so i can't just selectively use some of the pins? (e.g 4 digital IO pins) sorry. my bad 😞
01-13-2015 12:40 PM - last edited on 02-15-2024 11:20 AM by migration-bot
This is pretty old hardware. As Dennis mentioned, you can use a breakout board from the 68-pin D-SUB connector. The SCC-68 is listed under Accessories here. The SCB-68 is here. The SCB-68A is here. The pinouts are in the user manual here. I recommend reading through the different relevant sections of it for more answers. A link to the Lab/1200 Series support is here.
01-13-2015 08:45 PM
thanks guys. kudos to both of you.
