I am trying to control 4 relays with a 9263 compact DAQ module. I know the code works because 1 of the relays functions exactly as I intend and I get no errors. The problem is, no matter how I configure the other channels (select multiple using 1 physical channel control or use individual physical channel controls) only the 1st channel seems to function. I checked and the relays, DAQ, and power source all have good connections and properly function. Does the 9263 only support 1 AO at a time? I searched for this but wasn't able to find any answers specifically for the 9263.
There is no single channel limitation for the 9263- you should be able to update all 4 channels. Would you mind posting your code so I can take a look and see if I can see a reason why this might be occurring?
Thanks for the follow up regarding the 9263 capabilities. I have been doing additional tesing and it turns out the relays, code, etc. were good but 3 of my bench outlets were not. I'm up and running with all 4 channels now. I appreciate the help anyway!
