11-07-2007 07:17 PM
11-08-2007 01:45 AM
If you have a parallel port on your computer you can use it to address the MUX.
To keep things neat you only have to add a buffer IC, but for a first try not absolutely necessary.
11-08-2007 08:34 AM
11-08-2007 08:44 AM - edited 11-08-2007 08:44 AM
Hi Chris,
If you want you can stay here.
Actually it's pin 2 till 9 for the 8 data bits. But is you need more the other I/O signals can also be used.
How far are you (with LV and the Hardware) and what exactly is your application.
11-08-2007 09:00 AM
11-08-2007 09:14 AM
Normally I would say that the best way is to start with a course basic LV.
If you want to start now in LV then I think I have to make the program for. Not the best way but if you have the time, because I cannot always answer you as quick I do now, we will get a result.
Can you make a frontpanel in LV with the controls and/or indicators that you want ? We can start from there.
I assume that the HW part is no problem for you ?!?
11-08-2007 09:24 AM
11-08-2007 02:06 PM
11-08-2007 02:22 PM - edited 11-08-2007 02:23 PM
11-11-2007 03:09 PM
