Digital I/O
Configuring NI 9361 Terminal
I have 3 linear encoder and I will use NI9361. It wil be connected single ended encoder. But I do not need Z index signal. Can I configure it as digital input for error signal instead of Z signal? If it is possible, one module will be enough for me.
(1,866 Views)
What does Z signal mean?
(1,814 Views)
Z signal is reference signal at the encoder. All encoder does not have, if yours one has,  you must not connect it. Depends on your system
(1,803 Views)
Have you tried to configure NI9361 module ?
(1,697 Views)
Hi
I have just get the encoder and I tried it with NI 9411
(1,583 Views)
