12-09-2008 06:23 PM
I installed NIDAQmx 8.0 on my Red Hat Enterprise WS 4.6 machine. The driver installation seemed successful.
Using the nilsdev command, the following is listed:
NI PCI-6509: "Dev1"
Serial number: 0x13E94F3
Bus Type: PCI
PCI Bus: 0x4
PCI Device: 0x2
IRQ level: 0xC9
Memory Range: 0xDFAFD000-0xDFAFDFFF
Memory Range: 0xDFAFE000-0xDFAFFFFF
How do I ensure that the PCI-6509 card is working properly with my RHEL WS 4.6?
Wayne
Solved! Go to Solution.
12-10-2008
01:34 PM
- last edited on
09-19-2026
07:14 PM
by
Content Cleaner
Hi Wayne,
Welcome to the NI forums! The easiest way to verify that your device is working properly is to use a Test Panel. The following KnowledgeBase has instructions for how to open a Test panel in Linux: Test panels for DAQmx in Linux [link removed; article no longer available]
From the test panel you will be able to read from/write to the digital lines of the 6509 to make sure that the device is working properly. Thanks for posting and have a great day!
-John
12-10-2008 03:48 PM
09-12-2019
12:44 AM
- last edited on
09-19-2026
07:15 PM
by
Content Cleaner
hi John,
It seems that a link in Test panels for DAQmx in Linux is broken. I have also the same problem as mentioned previously for 6509 board. How can I opened a Test Panel on Linux by the way.
thanks,
Dexter
