03-19-2023 07:59 PM
Hi all,
currently, we apply NI-9223 and NI 9264 as a standard part of our DAQ system. However, we are now discussing if we could swap NI-9223 to NI-9201 whose sampling rate is 500ks/s/ch as an affordable alternative. We don't need the sampling rate as fast as 1Ms/s/ch actually. The difference of resolution doesn't mean too much in our test. So, is it workable?
Many thanks
03-19-2023 09:18 PM
You lose quite a lot of features and it is even possible that 9201 may not even fit your application.
From software, it might work just fine but hardware performance is widely different.
03-20-2023 04:07 AM
it does lose some key feature as I look more close at the specs like simultaneous sample. In general, may I say, I can use 92-series without any compatibility issue despite losing some features. For example, I pick up 9225 or 9222 with inferior sampling rate.
