Dear,
I am a newbie with DAQ, but I'm making a small program to be able to read in some open/close contacts.
The problem I encounter, is that I can read all ports (from P0.0 through P0.7), except ports P0.1 and P0.2 ...
(System = Centos 5.5 with NI-DAQMX Base; Device = NI USB-6501)
My program responds when I close contact P0.0 as follows:
After closing P0.0 :
Data changed from 0xFF to 0xFE
After opening P0.0 :
Data changed from 0xEF to 0xFF
But with P0.1 and P0.2 it does not respond at all... ??????
Below my little program I have:
#include "NIDAQmxBase.h"
#include <stdio.h>
#define DAQmxErrChk(functionCall) { if( DAQmxFailed(error=(functionCall)) ) { goto Error; } }
int main (int argc, char *argv[])
// Task parameters
int32 error = 0;
TaskHandle taskHandle = 0;
char errBuff[2048];
// Channel parameters
const char chan[] = "Dev1/port0";
// Read parameters
uInt8 r_data[1], r_data_old[1];
int32 read;
system("lsdaq");
// Create Digital Input (DI) Task and Channel
DAQmxErrChk (DAQmxBaseCreateTask ("", &taskHandle));
DAQmxErrChk (DAQmxBaseCreateDIChan(taskHandle,chan,"",DAQmx_Val_ChanForAllLines));
// Start Task (configure port)
DAQmxErrChk (DAQmxBaseStartTask (taskHandle));
// Read from port
DAQmxErrChk (DAQmxBaseReadDigitalU8(taskHandle,1,10.0,DAQmx_Val_GroupByChannel,r_data,1,&read,NULL));
r_data_old[0]=r_data[0];
do{
if (r_data_old[0]!=r_data[0]){
printf("Data changed from 0x%X to 0x%X\n", r_data_old[0], r_data[0]);
sleep(1);
while (1);
Error:
if (DAQmxFailed (error))
DAQmxBaseGetExtendedErrorInfo (errBuff, 2048);
if (taskHandle != 0)
DAQmxBaseStopTask (taskHandle);
DAQmxBaseClearTask (taskHandle);
if (error)
printf ("DAQmxBase Error %d: %s\n", error, errBuff);
return 0;
