Digital I/O
Can i trigger analog card using RTSI line from digital card
I want to synchronize a PCI-DIO-32HS with a PCI-6713 and IMAQ1409 via RTSI lines and using the 32HS clock. I also need to trigger these devices from the 32HS.
(2,852 Views)
Greetings,
Yes, both your PCI-DIO-32HS and PCI-6713 boards are able to send and receive clock and trigger signals through the RTSI Bus. Thus, you could trigger and clock your 6713 with your 32HS. I would suggest that you take a look at the examples installed with LabVIEW or NI-DAQ, and you should also search the examples available on the NI's web site -- HERE. I see that there are a number of examples designed to synchronize a 32HS with an E-Series device. These would not require a great deal of modification to substitute your 6713 for the E-Series board.
Good luck with your application.
Spencer S.
(2,852 Views)
