12-28-2010 02:10 AM
Hi
I'm using the NI6509 and NI 6509e. According to the specifications, the minimum input voltage is 2V.
Does it mean, I can input a LVTTL signal (3.3V) ?
Is it recommended to use it like that? The alternative is to use a circuit to convert LVTTL to TTL, but, obviously, I'll be happy not to do it if not necessary.
Rafi
12-28-2010 04:55 PM
You should be able to use the LVTTL signal directly as 3.3V is above the 2V minimum that is required to register as a logic high for an input.
Best Regards,
12-28-2010 05:10 PM
Hello Rafi,
I believe you shouldn't have any issues with using the NI-6509 to read a LVTTL signal. Just to be clear though, our device will not read a Logical high value until the voltage is above 2 Vs. I believe that since you have about 1.3Vs of clearance from this threshold you shouldn't run into any issues.
If you do notice issues with this, converting this to a TTL would be a good solution as well.
