I have a NI-9425 module that I would like to sample at 1kHz with some other analog input modules that are currently being sampled at 1000 Samples/sec and 100 Samples/Interrupt. Can the NI-9425 module be buffered with the sample scan and interrupt rate?
Hardware timed up to 140kHz. Yes, I would say this should work for you.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
It should be fast enough, but I haven't figured out how to buffer it. I can access the module about once very 60-70 ms and retrive one sample. I would like to retrive 100 buffered samples at a time because it seams to take about 60-70 ms for the labtop to read the module.
