01-28-2009 10:33 AM
I finally figured out how to change the firmware of my USB-6501 to work with DAQmx Base, only to find out that I can't use the channel property node to change the output driver type to "active drive". Is it possible to change the digital output driver to active drive in DAQmx Base? Ultimately I'd like to incorporate it into the Interactive Control vi that comes with Base. I'm using LV 8.6, and Base 3.2.
Thanks in advance,
Mike
01-29-2009 12:24 PM
Hi Mike,
As you have found out, the channel property nodes can only be accessed for the DAQmx driver. However, there is a DAQmx base task configuration utility that should enable you to achieve the "active drive" functionality. This utility can be found in the help dropdown menu within LabVIEW. According to this KnowledgeBase article, set the DIO Voltage Level property to 0-3.3V to configure the equivalent of the "active drive" property value.
David
Applications Engineer
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
