Greetings,
The DIO lines of your DAQ device need to be able to drive SSR-OAC5. The SSR-OAC5 is specified at needing a minimum input current of 12mA. There are some devices that are unable to meet this specification, but the PCI-6601 board is not one of them. You may refer to the following Knowledge Base entry for more information.
Why Can't SSR Output Modules Be Used with Certain DAQ Devices?
http://digital.ni.com/public.nsf/websearch/3F33283974B3692786256894006D7953?OpenDocument
The PCI-6601 has 32 DIO lines. You should not have a problem controling the SSR-IAC5 and SSR-OAC5 from the same device.
Justin Britten
