06-09-2009 10:41 AM
I am trying to investigate the use of the 'allow regeneration' option of the BufferControl.vi (used in the DIOStart.vi). I have attached a simple program that allows the user to select the data they want to output, which uses all 4 ports of the DAQCard 6533. I want to have this data output The program should have the BufferControl set to allow regeneration of the data.
My question is - where do I loop the program? Do I need to put another DIOWrite after the DIOWait? I have tried several things, but keep getting errors. It seems as if it should be fairly simple, but maybe I need a better understanding of how the buffer works.
Thanks in advance for your help.
06-10-2009 05:09 PM
Hi Operative,
Typically, the loop goes after the start and before the clear. What errors are you receiving? Does anything change when you implement the loop?
