ni.com is currently experiencing slowness/issues due to ongoing maintenance.
Support teams are actively working on the soonest resolution.
03-02-2006 07:05 AM
03-03-2006 05:02 AM
Hi Rod
I have attached a bit more information about some of the cards, the help file for the 65XX devises and a knowledge link for Sinking and sourcing. As you want a card to provide the power you want a sourcing cared i.e. the 6514 or 6516 as you said earlier.
I don’t understand what you mean by this comment
simply *switch* current up to the stated limit, or if they can *provide* the current
The NI 6514/6515 devices are 30 V bank isolated data acquisition (DAQ) devices for PCI, PXI, or CompactPCI chassis. The NI 6514/6515 devices feature 32 digital input lines and 32 digital output lines for sourcing (6514) and sinking (6515) current, a watchdog timer, digital filtering, and programmable power-up states.
The NI 6516/6517 devices are 30 V bank isolated data acquisition (DAQ) devices for PCI chassis. The NI 6516/6517 devices feature 32 unidirectional digital output lines for sourcing (6516) and sinking (6517) current, a watchdog timer, and programmable power-up states.
DI/O help
http://digital.ni.com/manuals.nsf/websearch/C17970161F11D53A86256F19006E693C
Understanding Sinking and Sourcing
http://digital.ni.com/public.nsf/websearch/A10122C63A7F5CFE86256B4C007491DD?OpenDocument
I hope this makes it easier to make an informed decision
Tim
NI
03-03-2006 05:59 AM
Thanks for that Tim, but I still don't understand.
The help file you indicated shows that one should connect an external power supply to VCC on either the 6514 or the 6516 to drive the load. What I need is to connect a load, say between Px and GND, without the need for an external power supply. (The load would be switched on upon expiry of the watchdog) The load I have in mind would require about 30mA at 5V
Rod.
03-03-2006 09:37 AM
Hi Rod
I have had a good look and I can’t find a PCI card that will source that much power with a hardware watch dog, i think this is due mainly to PCI specifications. You will have to use an external power supply and either an amplifier or really setup depending on whether or not you need a varying current.
Regards
Tim
03-03-2006 09:40 AM
or even a relay setup
