Digital I/O
Bend Labs Digital Flex Sensor - 1-Axis
Hello All
I want to hook up the Bend Labs Digital Flex Sensor - 1-Axis to myRIO, but based on it has two pins, nRST and nDRDY, and I do not know which pins of myRIO are these?
Can anyone help me with the wiring it to myRIO?
picture of it is attached.
(2,632 Views)
Based on what I understand, MyRIO only have AIO, DIO and UART (Universal Asynchronous Receiver and Transmitter) line which it is not suitable to be used with the bend sensor you had mentioned. You may refer the following links for more informations about the connector pinouts of the myRIO and also the porting guide for the bend sensor.
USER GUIDE AND SPECIFICATIONS NI myRIO-1900: http://www.ni.com/pdf/manuals/376047c.pdf
Getting Starter Guide: https://github.com/bendlabs/one_axis_ads/blob/master/documentation/one_axis_quick_start_guide.pdf
Porting Guide: https://github.com/bendlabs/one_axis_ads/blob/master/documentation/ads_porting_guide.pdf
Thanks.
Najwa
(2,581 Views)
