11-20-2008 09:19 AM
Hi everyone,
I am using a 6229 PCI card and Labview 8.5 with XP.
I need to generate every 10 secs a Digital Output that is low for 3 secs low and high the rest of the time. I have attached the VI that works fine with my previous values (500 ms and 2000 ms). However I get a low state for 1 sec, 2secs or 3 secs but not continously 3 secs when I used it with the 3secs/10secs values.
It works if I use the values 3secs/15secs (15 secs or higher).
There must be a problem with my looping but I don't understant what the problem is, since the outside loop should be waiting for the inside loop to finish before starting a new loop. I don't get why my low state time is affected by the exterior time loop...
This is probably a basic pb for you, but any help would be great,
Marc
11-20-2008 10:02 AM - edited 11-20-2008 10:03 AM
It seems overly complex. Below is an alternative. I used the Delay function since it has the error in/error out connections to enforce data flow. I also changed the type of DAQmx Write since you seem to be only writing to a single line.
11-21-2008 08:21 AM - edited 11-21-2008 08:29 AM
Hello.
The best solution is to use a counter rather than a digital out line, and to set a frequency of 0.1Hz and a duty cycle of 0.7 . You would have in this case a better timing accuracy for your generated signal.
11-23-2008 12:04 PM
Hi Dennis and Mehdi,
Thank you for your help. Dennis, you solution works out fine and I will use it. However, if anybody could tell me why my VI has this strange behaviour. I would like to understand what the problem is.....?
Mehdi, I know the 2 output counters are more accurate, but I don't need any very accurate outputs for the moment. I prefer to leave them available in case I need them in the futur.
Marc
