Hello Dave,
"For read, if I assign "Dev1/port0", create a DI channel and use DAQmxReadDigitalU32, will the state of the 32 IO lines on ports 0 - 3 be read into the return array? Will the LSB (little endian) contain the state of port0, line 0?"
No, you will have to read from channels "Dev1/port0:3" to read all 32 bits. The LSB is P0.0.
"For write, if I assign "Dev1/port4/line0:7", create a DO channel and use DAQmxWriteDigitalU8, will the state of port 4 reflect the value specified? I'll assume the endianess also applies here."
Port 4 should match the value you wrote. P4.0 will be the LSB.
Let me know if you have any further questions.
Sean C.
