Digital I/O
After I installed NI-DAQ 6.9 software I now get error -94 at bootup.
I got a new DIO-24 card and the NI-DAQ 6.9 software came with it. After installing the software, shutting down and installing the card, I rebooted the system. I got and continue to get Error in call to LoadPanel. UIR File Name: installui.uir Error Code -94.
I don't want that. I can find the file on the CD but I don't know what the real issue is with the error.
(3,508 Views)
Dale;
That is happening because you probably installed the new version of NI-DAQ on the top of the old one, without uninstalling it first. Now, you will need to uninstall everything, clean the windows registry entries up, and install NI-DAQ 6.9.1 from scratch.
To unsitall the driver, go to Add/Remove programs, and to clean up the registry, type RegEdit in Start->Run, and go to HKWY_LOCAL_MACHINE->Software->National Instruments, and delete the NI-DAQ folders, if they are still there after you unistall everything.
Hope this helps.
Filipe
(3,508 Views)
