Reply
Adapt OPTO-22 relay board to SCXI 1163
I need to adapt a scxi 1163 board so the digital outputs drive a OPTO-22 24 position backplane in a 1 to 1 fashion.  Is there a cable or series of cables which does this in a clean manner?
(1,299 Views)
Re: Adapt OPTO-22 relay board to SCXI 1163
Hello TechJim,
Thanks for your post!  I see that you are wanting a way to easily get the pins of the 1163 to connect to your OPTO-22 24. There is a NI TBX-1326 that allows you to break out the connects a little better than the SCXI-1326 Terminal Block Front Mount.
NI TBX-1326
SCXI-1326
Let us know if this helps!
Cheers!
Corby_B
http://www.ni.com/support
(1,286 Views)
