I need to adapt a scxi 1163 board so the digital outputs drive a OPTO-22 24 position backplane in a 1 to 1 fashion. Is there a cable or series of cables which does this in a clean manner?
Thanks for your post! I see that you are wanting a way to easily get the pins of the 1163 to connect to your OPTO-22 24. There is a NI TBX-1326 that allows you to break out the connects a little better than the SCXI-1326 Terminal Block Front Mount.
