06-29-2022 03:24 AM
I'm using USB-6361 and want to get 2 channels AI and 4 channels DI simultaneously.
For example, 50,000 data for each channel, and they should be synchronized. The first AI data and the first DI should be acquired at the same time and the last data also.
I did it for same number of AI and DI channels as below, with python code.
import ctypes
self.nidaq = ctypes.windll.nicaiu
self.int32 = ctypes.c_long
self.uInt32 = ctypes.c_ulong
self.uInt64 = ctypes.c_ulonglong
self.float64 = ctypes.c_double
self.char = ctypes.c_char
self.char_p = ctypes.c_char_p
self.DAQmx_Val_GroupByChannel = 0
self.DAQmx_Val_GroupByScanNumber = 1
self.DAQmx_Val_Acquired_Into_Buffer = 1
self.DAQmx_Val_ChanPerLine = 0
self.TaskHandle = self.uInt32
self.AItaskHandle = self.TaskHandle( 0 )
self.DItaskHandle = self.TaskHandle( 1 )
samplesPerChanAI = int(maxNumSamples/3.)
samplesPerChanDI = int(maxNumSamples/3.)
self.AIdata = numpy.zeros( ( maxNumSamples ), dtype=numpy.float64 )
self.DIdata = numpy.zeros( ( maxNumSamples ), dtype=numpy.uint8 )
AIdata_dummy = numpy.zeros( ( maxNumSamples ), dtype=numpy.float64 )
Length = AIdata_dummy.size
self.nidaq.DAQmxCreateTask("",ctypes.byref(self.AItaskHandle))
self.nidaq.DAQmxCreateTask("",ctypes.byref(self.DItaskHandle))
self.nidaq.DAQmxCreateAIVoltageChan(self.AItaskHandle, b"Dev%d/ai0,Dev%d/ai1,Dev%d/ai2" %(num, num, num), "", const.DAQmx_Val_Diff, self.float64(-5.0), self.float64(5.0), const.DAQmx_Val_Volts,None)
self.nidaq.DAQmxCreateDIChan(self.DItaskHandle, b"Dev%d/port0/line0:2" %num, "", self.DAQmx_Val_ChanPerLine)
self.nidaq.DAQmxCfgSampClkTiming(self.AItaskHandle, "", self.float64(sampleRate), const.DAQmx_Val_Rising, const.DAQmx_Val_ContSamps, self.uInt64(500000))
self.nidaq.DAQmxCfgSampClkTiming(self.DItaskHandle, b"/Dev%d/ai/sampleClock" %num, self.float64(sampleRate), const.DAQmx_Val_Rising, const.DAQmx_Val_ContSamps, self.uInt64(500000))
self.nidaq.DAQmxStartTask( self.DItaskHandle )
self.nidaq.DAQmxStartTask( self.AItaskHandle )
while True:
bytesPerSamps = self.uInt32()
self.nidaq.DAQmxReadAnalogF64(self.AItaskHandle, samplesPerChanAI, self.float64(-1), self.DAQmx_Val_GroupByScanNumber, self.AIdata.ctypes.data, Length, ctypes.byref(self.readAI), None)
self.nidaq.DAQmxReadDigitalLines(self.DItaskHandle, samplesPerChanDI, self.float64(-1), self.DAQmx_Val_GroupByScanNumber, self.DIdata.ctypes.data, Length, ctypes.byref(self.readDI), ctypes.byref(bytesPerSamps), None)
#break at some moment when the DAQ ends
self.nidaq.DAQmxStopTask( self.DItaskHandle )
self.nidaq.DAQmxClearTask( self.DItaskHandle )
self.nidaq.DAQmxStopTask( self.AItaskHandle )
self.nidaq.DAQmxClearTask( self.AItaskHandle )
However, when I change the number of DI channels and sampling rate for DI, the sync between AI and DI no longer matched. Total number of sample are same, for example AI 100,000 samples (50,000 for each channel) and DI 100,000 samples (25,000 for each channel) at each read. (sampling rate is 1MS/s for AI and 500kS/s for DI)
Please let me know if you have any idea or need further information.
Thank you in advance. 🙂
Best wishes,
JESuh
06-29-2022 07:36 AM
Since the DI sampling clock is configured to use AI's sampling clock, you cannot have different rates for DI and AI.
