11-02-2017 02:51 AM
I would like to connect a Broadcom HFBR-1521 LWL Transmitter to the NI 9402 DIO in a cRIO-9063 cabinet.
What is the maximum Output Current of the 9402?
If it is below 20mA I'm going to use an additional driver.
Best Regards,
Chris
11-02-2017 04:19 AM
Most DIO only handle more around 4mA. From what I am seeing in the spec, I would say the 9402 is rated for 2mA. So you will definitely need a buffer circuit.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
