Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Digital I/O
8452 streaming API change chip select
I am able to stream a command successfully using the streaming API.  However, it the default is CS=0.  How do you change and use the other chip selects?   I want to be able to select CS0 to CS7.
Bob
(3,829 Views)
Hello Bob,
Can you post a screenshot of your code, specifically where CS0 is being set and which function/VI you're referring to?
(3,808 Views)
Here is the labview code.  There is no where to change the chip select.  It defaults to CS0.
(3,726 Views)
