Digital I/O
8 PWM signals with 9401
I am looking into producing 8 PWM signals using an NI-9401 in a cDAQ-9174. Ideally each PWM signal would be able to have a different duty cycle, but run at the same frequency (25kHz). From what I've read in the link below, I cannot accomplish this using counters.
https://forums.ni.com/t5/Digital-I-O/Compact-Daq-cDAQ-maximum-PWM-outputs-PWM-output-module/td-p/371...
I am thinking there is a way to do this by coding the digital outputs to run off the 20MHz hardware time base, but I'm not sure if this is feasible. I would appreciate it if someone could give me a quick answer as to whether my suggestion is possible or if I'm wasting my time.
Thank you.
(2,304 Views)
The maximum number of counter task is only 4 on cDAQ-9174.
Number of Concurrent Tasks on a CompactDAQ Chassis Gen II
You can control PWM up to 4 but cannot more.
The capability of digital output depends on cDAQ chassis.
SPECIFICATIONS NI cDAQ™-9174
According to "Digital Waveform Characteristics",
"Digital output sample clock frequency" is up to 10MHz...
Certified LabVIEW Developer
GCentral
(2,281 Views)
