‎02-20-2009 06:35 AM
Solved! Go to Solution.
‎02-23-2009 04:30 AM
I didn't understand something. You have a nand memory but you have not connection to you board, so where is the memory? Have it he same ground?
regards,
Aurélien J.
National Instruments France
‎02-23-2009 04:40 AM
‎02-23-2009 10:01 AM
The memory is connected to the board with wires and a TSOP support.
Clock is configured to low level. The clock setting is " on board clock" for generation session and I export this clock to the acquisition session by the DDC connector.
Acquisition is triggered by a pattern match.
‎02-26-2009 03:46 AM
Ok it works !
It was a termination problem as i said...My pcb needs a 10K parallel termination.
Thank you for helping me to think !
