05-06-2009 06:39 PM
The help files for the 655x (Devices -> NI 655x -> Hardware Architecture -> Signal Routing) has a table that shows the 6551 internal sample clock as a source and the PXI_STAR as a destination. I have tried to set this up but it comes back with a runtime error stating that the hardware does not have this capability. I have the 6551 in slot 2 of the PXI rack. Am I misunderstanding the routing table in the help file.
Part of the code......................
//configure internal generator clock to be 2 Meg
ErrChk(niHSDIO_ConfigureSampleClock(*viGen[out_card_number], NIHSDIO_VAL_ON_BOARD_CLOCK_STR, 2.0e6));
//export sample clock on the co-ax clock out signal
ErrChk(niHSDIO_ExportSignal (*viGen[out_card_number], NIHSDIO_VAL_SAMPLE_CLOCK, VI_NULL, NIHSDIO_VAL_PXI_STAR_STR));
//do a commit to start the output clock
ErrChk(niHSDIO_CommitDynamic(*viGen[out_card_number]));
Andrew
Solved! Go to Solution.
05-11-2009 10:44 AM
Hello Andrew,
The documentation is actually incorrect. Only certain devices can actually drive the PXI_STAR line as a destination and the 655x devices cannot. This was a mistake in our documentation and has been reported to R&D under ID #166056. I believe the following devices can drive the PXI_Star line from slot two:
Please let me know if you would like to use one of these devices and we can have someone from their product group verify that they will be able to drive the PXI_Star line.
Paul C.
05-12-2009 11:33 AM
Hi Paul,
Thank you for the reply.
At this time I do not need any more information on cards that can drive the PXI_STAR line.
Over the last year we have purchased 42 of the 6551 cards and I am experimenting with them to find out exactly what they can do. For now this is all the information I need.
Regards
Andrew Quick
05-12-2009 04:44 PM - edited 05-12-2009 04:45 PM
Hello Andrew,
Just thought I would add some articles that I found pretty great for learning about the features of our High Speed Digital I/O devices. One article is about some of the advanced features and can be found here. In addition, the product support page for the PXI-6551 has some other great links here. In addition, we have some great reference libraries now available for JTAG and I2C. They are available here and here respectfully.
Please let me know if you have any additional questions.
Paul C.
