I made a slight change on the onboard looping output&input sample,
choose port0,1 as output group, generate pattern continuously
choose port2,3 as input group, read pattern back only once.
I have connected the REQ1 with REQ2, I also set the input group/read active low, while the output group/generate active high,
Running the modified VI, it always shows that Error -10629, the setting is exactly the same as the onboard looping output&input VI. I have tried for nearly 3 days but but I just could not find out the reason. Would anyone be kind enough to help me out...please....
