Digital I/O
6534 pattern I/O ouptut with external clock
I am attempting to use a 6534 DIO card to perform buffered pattern output with external clock tied to REQ input.  I seem to be limited to about 2Mhz clock, does this seem correct?
(3,299 Views)
jimhar,
I will need to know a little bit more about your set up.  Are you doing a finite or continuous pattern output generation?  Are you sending 8 bit, 16 bit or 32 bit samples?  Why do you say that you are limited to 2 MHz?  Are you getting an error of some kind when you go above that frequency?  Does your external clock look pretty good or does it have some noise?
Jeff Tipps
(3,289 Views)
