05-24-2006 09:29 AM
05-25-2006 11:00 AM
05-25-2006 11:03 AM
05-25-2006 12:02 PM
05-26-2006 11:56 AM
05-26-2006 02:31 PM
05-30-2006 04:42 PM
Hi J,
So, if you want to acquire data on a single digital line, you will be able to modify the example that Lon posted. Currently, his example is setup for 4 lines: all that you need to do is delete three of the digital input lines in the DAQ Assistant and then you won't have to index the array coming out of the DAQ Assistant either. I was also wondering if you gave any thought to acquiring this data via the serial port on the computer.
Hal L.
