For most products licensed with NILM, licenses will be set up to use the standard licensing options:
- 7 day evaluation without login
- 45 day evaluation with login
- Single Package/Single Component
- No families
For these products, please see the Licensing Third-Party Products with the NILM Third Party SDK
If additional or different licensing capabilities are needed, please discuss this with the LabVIEW Tools Network team before requesting a license. In order to handle some of the advanced capabilities, you'll need to create Family and Mapping XML files.
Creating the Family XML File
Complete the following steps to create a Product Info XML file for a specific version of a family.
- Fill in the fields in the Family XML tab of the XML File Generator. Most of the fields in the Family XML tab are self-explanatory. The following list describes fields that might require additional explanation.
- Family Name – Name that is appended to the beginning of the XML filename. The format for this field must be FamilyName_Descriptor_Version, where version is in the format nnnnnn.
- Family Version – The version of the family. The format for this field must be nn.nn.nn.
- Click Save Family XML File and save the Product XML file in the C:\ProgramData\National Instruments\License Manager\ProductInfo
Mapping Licenses to Products
Use the Mapping XMLs tab to map license files to products or families.
To map a license file to a product, complete the following steps:
- Fill in the fields in the License Mapping XML section of the Mapping XMLs tab of the XML File Generator. Most of the fields are self-explanatory. The following list describes fields that might require additional explanation.
- Package Name – Corresponds to the value of the PACKAGES field in the .lc file for the product.
- Product Prefix – Name that is appended to the beginning of the XML filename.
- Click Save License Mapping XML File.
To map a license file to a family, complete the following steps:
- Fill in the fields in the Family Mapping XML section of the Mapping XMLs tab of the XML File Generator. Most of the fields are self-explanatory. The following list describes fields that might require additional explanation.
- Family Name – Corresponds to the value of the FAMILY field in the .lc file for the product.
- Click Save Family Mapping XML File.
