» Developing a VI-Based API » Adding a Help Document Link to the Context Help
This example will walk through the process of adding a 'Detailed Help' link to the context help to load a help document when clicked. To prepare for this example, please copy the 'help' folder from the .zip archive below to your LabVIEW directory (if prompted, choose to merge with the existing help folder).
Note: You can also launch the help document from the Help menu if you select the 'ATX Simple Math Help' entry. The help document is an html file and the LabVIEW Help menu only auto-populates entries for CHM, HLP, and VI file types in the LabVIEW\Help directory; in order to create an entry for the html file used in this example, a launching VI was necessary. This approach can be taken to launch other help document file types, such as PDF documents, from the LabVIEW Help menu.
Happened to run across this example while searching for something else, and wanted to comment.
What is the point of the VI in the folder with the help file? It serves no purpose as far as actually accessing the help file.
The purpose of the example is to demonstrate how to add a context help link to an API VI in order for the 'Detailed Help' link to load a help document. The Help file and VI placed in LabVIEW\Help\ also demonstrate how to add an html help file to the LabVIEW Help menu, through use of a launching VI; I meant to add a note to the example to point this out, it's there now!
Thanks for pointing this out!
Or you could do it automatically without bothering to get into relative and symbolic paths with a HELPer tool for VI documentation (http://vigods.com/toolkits/HELPer/helper.html)
Igor, it may be a nice tool, but what you do on this board slowly approaches spamming. Also if the website was created with the same tool, it makes me wonder. At least in my Firefox browser the link you show in your multiple posts today all show a rather unreadable (help like) page where the frames (or whatever it is) are rather and unnecessarily small and don't show all the information, eventhough 70% of my browser window is blank.
rolfk, 1) website wasn't created with the same tool, 2) we are approaching HTML5 era, so you should update your browser, or use more standard compatible ones (currently it's Chrome) - then it should be Ok, 3) there is a list of examples on vigods.com, where you can have a look at different options, for example at 4) http://vigods.com/toolkits/HELPer/example/aes/helper_advanced/AES.Encrypt.vi.html
Anyway, this particular document is exactly about what I'm talking about, and by the way I'm trying to save time of many people, including yours. So, my comment is relevant here.
Well, adding a link to your page to every thread that has something to do with help file documentation is feeling a bit spammy, sorry!
And expecting everyone to have a fully HTML5 conforming browser may be a little heavyweight. It's not like I'm using Firefox 3.x or something, but I refuse to upgrade every month.
