Developer Center Blog
Community Browser
Re: Time to Test Drive LabVIEW 2014 Beta!
David_L
It's that time of the year again.  The LabVIEW 2014 beta 1 has officially been released and it's time to sign up.   We are working on a few new features that will directly benefit LabVIEW Tools Network products which you should especially test out:
(Note: links below will not work until you have been accepted to the LabVIEW 2014 beta program)
Even if you don’t plan to use these new features right away, it is important to test your products with the 2014 beta to ensure their compatibility with the new version and make sure no unexpected issues are introduced into your product (we don't usually do this on purpose, but mistakes happen!).  The sooner you do your testing, the better chance we can fix any bugs before 2014 is officially released.
You can sign up for the new LabVIEW 2014 beta at ni.com/beta.  Please sign up, test your products and give feedback via the beta forum.
Comments
Manu56
Hi David,
TPLAT support policy is to support current + last three versions of LabVIEW. So TPLAT 2014 will support LabVIEW 2011 - 2014.
My understanding of this is that LVTN products compatible from former versions (2010 or earlier) won't have the possibility to be licenesed through TPLAT 2014 get advantages of the TPLAT 2014.
For example, does this means that if we want a licensed product to get the possibilty of having its license transferred then it has to be licensed through TPLAT 2014 ? If yes, this means that the licensed product can only compatible with the last three versions of LabVIEW (2011 - 2014) ! ...
David_L
Please see my response to this on the LabVIEW Beta Forum.
