Licensing Third-Party Products with the NI License Manager API for LabVIEW
You can include licensing for products that you add to the NI Tools Network using the NILM Third Party SDK. Add licensing to your product to provide evaluation periods for your customers, and allow access to certain features based on the license. This document contains information about licensing concepts and steps for adding licensing to your products.
Below is an Example Flowchart, which shows a generic algorithm for implementing the licensing.
System Requirements
To use the NILM API for LabVIEW you must have NI License Manager 4.0.1 or later installed on your computer.
Licensing Terms
Note: A typical product will only contain one component belonging to one package with no family. For information on advanced licensing scenarios, see Advanced Licensing with NILM
Obtaining a License
The NILM SDK is available for free to any third party software sold through the NI Tools Network. You can find information on selling your product at http://www.ni.com/labview-tools-network/contribute/. To obtain a license file, please see Requesting License Files for NI License Manager
The license file created using the above request process is the actual license file that will be used in your product, however it will initially be configured in a "test mode". This means that it can be used for development and testing, but is not linked to a real NI Part Number and therefore can't be sold. All licenses in test mode can be activated with the test serial number P12A00413. Do not distribute any software that uses test mode licenses. Additionally, it's not possible to use the extended (45-day) evaluation for licenses in test mode. Once your product has passed NI Tools Network review, the test mode license will be converted to an active license. Active licenses are linked to a real NI Part Number, the test serial number will no longer function, and extended evaluation will be enabled.
If you have any questions about converting your license, or selling your product through the NI Tools Network, please contact the NI Tools Network team.
Creating the Product Info XML File
The Product Info XML file defines the user-visible content of a license and contains information about a specific version of a package or family. To create this file, select Tools>>NILM Product Info XML Generator in LabVIEW to open the XML File Generator tool.
Complete the following steps to create a Product Info XML file for a specific version of a product.
Adding Licensing to Your Product Installer
After you obtain a license from NI, add licensing to your application using the functions or VIs in the SDK, and generate a Product Info XML file, ensure the following:
File |
Install Location |
License (.lc) file |
C:\ProgramData\National Instruments\License Manager\Licenses |
Product Info XML (.xml) file |
C:\ProgramData\National Instruments\License Manager\ProductInfo |
Using Set License Tag On Library to License LabVIEW Libraries
You can use the Set License Tag on Library VI when adding licensing to a LabVIEW Library, exactly like NI does for our toolkits. To accomplish this, please refer to the following guide: Licensing a Third-Party Library Using NI License Manager
Example Programs
The NI License Manager API for LabVIEW includes examples that illustrate how to use the functions and VIs in your applications. Access these examples using NI Example Finder.
