08-31-2020 09:38 AM
thanks first for this great framework!
we made a custom module template, and have created a new module from this template, for the first time.
and curious thing occured, when we tried to create another new module.
here is the error displayed.
we finally find the template api tester is moved inside the lvlib automatical, though this api tester is originally included in the "Tester" virtual folder, before the first time we use this template to create a module,like this.
and if we remove the api tester outside and back to the "Tester" virtual folder again, we can use this template to create new module again without error. but again, the api tester is moved inside the lvlib, and error occured.
09-01-2020 11:09 AM
I reported the bug directly to Delacor 2 months ago, and they created an issue.
I'm pretty sure that the next version of DQMH will come with a fix 🙂
To be curious, I came across the issue because I would like to duplicate an existing module inside my project. I created a feature request for that, by that way --> https://forums.ni.com/t5/DQMH-Feature-Requests/Add-duplicate-module-menu/idi-p/4062011
What was your use case?
09-01-2020 12:12 PM
It will be in the next release.
For now, when adding a new DQMH module from template, make sure the module used to create the template is not in the same project as to where you are adding the new module. You could create a blank project just to add your DQMH module and then move the module folder to the correct location. We apologize for the inconvenience and hope the workaround can help you out for now.
Thanks again for your trust in DQMH,
Fab
09-02-2020 06:50 PM
it is similar with your case. we define each test item as a module, and there are almost 40 test items in this project.
each test item will be loaded dynamic and we create a module "test execute" to act like a middleware to manage these items.
we have refered to HSE application template for way of dynamic loading and registering modules. this framework is a little bit complicated for us, so we just use simple dqmh template.
thanks.
09-02-2020 07:06 PM
all right, this is the way out and it works.
looking forward to the next release.
05-11-2021 10:58 AM
Hi Fabiola,
When will that update be released? I had the same problem with making a module from a template so it isn't in 5.0.0.72, which I believe is the latest rev. of Delacor QMH. Does the problem also mean that we can't use the template multiple times in the same project?
Thanks.
05-12-2021 07:13 AM
@carlos_camargo a écrit :
Hi Fabiola,
Thanks.
Hi Carlos,
DQMH 6.0 is on its way, thank you for your patience.
Waiting for the release, If you want to create a module from a module template that stands in your project, simply move back the tester to its original place after each creation.
05-12-2021 10:35 AM
Hi Olivier-Jourdan,
Thanks for that response. I have some new information on my problem. I created a simpler custom template in a different project. This one had no ties to the original project. This template I was able to use, even several times on my main project. Also, in the main project, the one with the template problem, there was a shared class-based instrument that was part of the template.
C
05-13-2021 03:50 AM
Do you mean that you have an issue with templates when the template is not in the project you want to add a new module to? That is the original issue this thread is about.
If so, can you please give us more information? What's the error you get when creating the new module, etc...
05-13-2021 06:38 AM
@royceking sorry for not reacting, I missed this paragraph when I read this thread the first time.
If you find the time, could you elaborate on what made it difficult for you to go with the HSE application template? Which parts were too complicated? Where should we add comments or documentation?
We'd appreciate your input. Thanks in advance!
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (The Future of Team-Based LabVIEW Development)
