[Zuehlke] Project explorer menu for DQMH
Hello Claude,
thanks so much for the quick response !!
Much appreciated !
Cheers
Niels Göran
Message 31 of 38
(1,815 Views)
I have been working on a new Project explorer menu, which is already in use internally.
It offers the following functions:
- Create all Unit Test for DQMH module Requests
- Create all Unit Tests for multiple DQMH modules
- Create Unit Tests for selected VIs of Libraries
- Patched GOOP IconEditor without (sometimes) deleting the "VI description"
- Templates for the Setup/TearDown/UnitTest VIs (based on Caraya)
Is there anyone interested in this extension?
@fabiola: Is it okay for you if this extension uses some DQMH scripting functions?
Claude
CLA / CTD
Message 32 of 38
(1,709 Views)
Claude
Yes! You have my authorization. go for it! I am assuming that you will share some of this with us too, correct?
I will continue to give you early access to the DQMH Beta version so you can let us know if we accidentally break one of the project provider tools you created.
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
Message 33 of 38
(1,705 Views)
Sounds interesting Fridu.
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
https://wiredinsoftware.com.au
Message 34 of 38
(1,693 Views)
Hello Fab, yes thanks for the authorization! I will release the tool within the next weeks and I am curious about the reactions!
CLA / CTD
Message 35 of 38
(1,676 Views)
I have not been able get the install for this to work correctly. There is no drop down in the project explorer. I am using LV 2018 please give me a heads up on what might be wrong. I have tried to install every version with no success.
ignore resolved...
Message 36 of 38
(1,564 Views)
Accepted by topic author FabiolaDelaCueva
We are moving our tools to the VIPM. More interesting tools will follow! 😉
https://www.vipm.io/package/zuehlke_engineering_dqmh_provider_for_the_project_explorer/
https://www.vipm.io/publisher/zuehlke-engineering/
CLA / CTD
Message 37 of 38
(1,507 Views)
Excellent idea! Thanks for sharing your tool with everyone.
The DQMH Trusted Advisors have also added your tool  to the VIPM package list called "DQMH Trusted Advisors List" that contains the packages that the DQMH Trusted Advisors recommend:
https://www.vipm.io/package-list/2e093e6e-e1a0-4b09-acae-a8ddb518b727/
Thanks!
Fab
Message 38 of 38
(1,488 Views)
