06-12-2017 08:58 AM
Dear DQMH Developer Team,
We are currently trying to create a DQMH Project without the "Do Something" events. The steps we perform are:
1) Create Project from template containing a Singleton and a Cloneable module, both without the "Do Something" event
-> The project is created and everything looks good.
2) Add a Singleton module without the "Do Something" event using Tools -> Delacor -> DQMH -> Add new DQMH Module...
-> The Module is created, however both the Main.vi in the library and the Test [..] API.vi need four VIs, which are not contained in the Project (picture attached). These are not created, since we chose not to create the "Do Something" event.
What are we doing wrong? We are using the following configuration:
Windows 7 Ultimate 64-bit
LabVIEW 2016, 32-bit
Delacor QMH Project Template 3.1.0.34
Any help is greatly appreciated,
Jascha Eisenberg
06-12-2017 11:13 AM
We were able to reproduce the issue you are experiencing. We will investigate further and give you a solution.
In the meantime, the workaround is to create your Singleton DQMH module on a blank project and then add it to the project where you wanted to use it.
We apologize for the inconvenience and thanks for letting us know.
Fab
03-25-2018 06:15 PM
This issue has been solved in DQMH 4.0. You can download the Beta version here
http://delacor.com/announcing-dqmh-4-0-beta/
