08-06-2018 03:04 PM
For clonable modules, would there be any examples of how to use "Test Clone Registration API.vi" ?
08-07-2018 06:29 AM
The Test Cloneable Registration API is there to show/test how the rest of the VIs in that library work. The library is completely copied into your cloneable module. If you decide you would like to modify clone modules registration, you can use that tester to make sure the rest of the code would still work.
Let us know if you would like for us to make a video describing this VI.
08-07-2018 07:16 AM
Yes a video on how to use the Test Cloneable Registration API would be nice. I am working on a cloneable module that I would like to control 2 slightly different pieces of hardware. I was thinking of using the OOP-factory pattern to abstract the hardware, then launch 2 different clones of my module each configured, immediately after start, to load the correct drivers. I think I can still use the regular Tester to troubleshoot this scenario, but I was wondering what other goodies, such as Test Cloneable Registration API there were and what they did.
