11-04-2019 01:05 PM
Hi All!
I am a beginner in DQMH and I'm still seeking its usage to the fullest potential - I'd also like to to test my modules as decoupled and isolated as possible - and this is the reason for the question at hand:
Imagine we have Continuous Measurement and Logging DQMH template - with Logger, UI, Acquisition and Settings module. In Logger API tester there is a nice way to log whatever waveform we want, because it is a simple Request Event. I'd like to extend the testability of the UI module to the same degree - to somehow create the <Acquisition.Data Updated> User Event from my tester, that would go the same path as the original Event - but remain in the scope of the module. This way I'd be able to verify the UI behavior without the need of running the whole code and I'd be able to test some corner cases.
Till now, I was able to come up with two approaches to this thing:
1. Create an additional Integration Tester, starting both CML UI and Acquisition DQMH modules. This would move us from "unit" testing to "integration" testing and this depends on how well the Acquisition module is written when it comes to decoupling it from hardware. This is something I am looking into, but I'd really prefer to be able to pass any random waveform instead and isolate my tests.
2. Make an additional Request Event that matches the data type of Acquisition Broadcast Event. This gives me the level of isolation I want, but I end up with additional API calls that are only valid for the tests and I need to pay attention that my other developers are not using those for anything other than testing - not to mention the mess it creates.
Is there anything I am missing in my exploration of DQMH features that might come in handy in occasions like this?
Bartosz
11-05-2019 02:06 PM - edited 11-05-2019 02:11 PM
11-07-2019 07:32 AM
Hi Christopher,
Thank you for your input and for the thorough explanation. I think I'll go with one of the approaches that you've suggested and make my peace with this 🙂
Prior to DQMH I used simple forms of dependency injection and loose coupling of the modules, so the hierarchy of most of my work would not be as obvious as in the example code.
There is also a dirty-hack that I find a little bit tempting - making a wrapper on broadcast event query of the module I'd like to mock and make it Community acces, with Friends set to the Tester of the module I'd like to test - unlike Actor Framework, Events are not secured on their handles - instead of using them just for the registration it is technically possible (although a little bit dirty) to Generate an Event in the tester, using this ref - but I'll try to fight my temptation here 😉
11-08-2019 01:15 AM
Hi Bartosz,
Have you checked out the unit testing tools for DQMH?
https://delacor.com/documentation/dqmh-html/CreatingDQMHUnitTests.html
Fab
