12-08-2020 04:27 PM
I try to add parameters in cloneable module but encountered one problem.
There is a white square in place of cluster type in asynchronus call node, and i can't connect my Conf control. I have place my cluster parameter Conf in main Vi, connect them to the Main.vi connector, and drag and drop Main Vi connector in Main VI Type--strict_vi_ref.ctl as requested.
Any idea of what's wrong.
Eric
Solved! Go to Solution.
12-08-2020 04:35 PM
Is the parameter you're trying to add a private typedef in a library? Or does it contain private library typedefs? That's the only thing I can think of, other than your VI Connector Pane reference typedef having been disconnected somewhere.
Assuming those suggestions don't help, can you attach a simple module that demonstrates the issue?
12-08-2020 04:51 PM
Oups. I have found my error. It's because i have connect one indicator and not a control to the Main Vi connector.
But i discovered than IDE memorize connector for strict type Vi.
