Data Acquisition Idea Exchange
SSI (synchronous serial interface) Bus Module or card
Status: New
NI supports almost any bus.  Why not SSI (synchronous serial interface) ?
Of course, there is always the option to use an R series card and then build an interface.  Why not have a low-cost PCI or USB card? Also, perhaps a C-series module, so that we don't have to take up FPGA space?
4 Comments
John_P1
Trusted Enthusiast
To implement an SSI master, you essentially just need a way to synchronize a digital input to an exported clock and chip-select line.  This shouldn't be too difficult to implement using an M/X series DAQ device (example here).  C Series modules that support clocked DIO can run the same DAQmx code if used in a cDAQ chassis.  This might not fit everybody's definition of "low cost" but it should be less expensive than the R Series/cRIO route.
Maybe it would be a good starting point for NI to simply provide a more formal SSI DAQmx example/library.
John Passiak
A-T-R
Just for the records:
http://www.addi-data.biz/index.php/component/hikashop/product/6-apci-1710-multifunction-counter-boar...
There are also SSI-LV-Examples available, but it's just not "native"...
http://www.addi-data.com/treiber/apci1710/32bit/Labview/ssi_l.exe
Peter-daq.io
Even though I don't get commission, I would like to advertise Noffz' (German Platinum Alliance member) solution - It was designed to test SSI connected sensors:
Noffz cRIO 4422 module - it supports differential RS-422 and more specifically SSI. From their web site:
  • 4-channel differential digital output
  • 4-channel differential digital input
  • RS422 common mode -7V to +12V
  • Single ended TTL mode possible
  • Input delay time 46ns typ.
  • Output delay time 35ns typ.
Peter
CLD | Alliance Partner | Web data storage and visualization | daq.io
User002
Not applicable
