Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
IMAQdx Timeout is a non settable property. It is fixed on 5s
When I do not trigger my camera for 5 seconds (and that is what I want regularly after aquisitions at 100FPS) , I get a timeout error.
what camera are you using, I am able to set the frame timeout property with a wide range of cameras from different manufactuers.
the timeout can only be set while the IMAQdx session is not started, that indeed is an anoying limitation.
Epictetus
Antoine Chalons
Thanks!
We'll be in touch soon!
