Would like to be able to collect a couple channels of analog inputs to the iPad. This is nice but I need a minimum of 2 analog inputs and I would rather have NI: http://www.oscium.com/
Response from coorporate:
"We don't currently have anything that would meet
the customer's requirement of being able to plug in directly into the iPad for
data acquisition.
I don't believe
that the iPad supports Silverlight which is a framework developed by Microsoft.
Also, wireless DAQ has to communicate with a host running DAQmx, so the
customer would still need a 2nd computer even if using wireless DAQ.
If you want to connect data acquisition
hardware (of any form-factor) to a machine running LabVIEW and DAQmx, then use
LabVIEW Web Services to
publish the front panel to the web and view/control it from his iPad.
We do have several USB products that
will work with Windows-based netbooks that could be an alternative solution if
topic is open to a non-Apple platform. For example, the 5132/5133 are
bus-powered digitizers with much higher sample rate, bandwidth, and buffer size
compared to the Oscium device. However, the price is also quite a bit higher."
