I am curious what your use case is here. What format should the data be in? How would you use this information in an application?
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
Here my case is I have a PXIe-6365 module which has 144Analog Inputs, we are developing an application that helps the operator to connect the UUT test points to SCB68.
While my application is running I would like to inform the operator about the channel connectivity, Refer to the image captured from NI Max
