06-01-2010 03:37 PM
Test engineers and magicians have a lot in common; they are both expected to pull rabbits out of a hat on command. But it doesn't stop there. Test engineers are expected to pull test systems out of a hat while juggling multiple projects at the same time. Unfortunately, many test engineers are nearing the end of their bag of tricks for ensuring test systems are released on time and under budget, especially as the time to release a test system is continually shrinking along with test engineering head count and budgets.
An increasing number of electronic manufacturers have discovered that treating test like a product is essential for engineering a competitive test strategy. This enables them to ensure the optimum quality, budget, release date, and use of test resources.
Typically, the test-development phase of the NPI (new product introduction) process begins when the design process is complete. Test engineers are given the key product specs and a set of test requirements generated by R&D to ensure the product is tested properly. This is most commonly known as the "throw it over the wall" test-development strategy. Despite being an oft-ridiculed approach and the source of many engineering jokes, this test-development strategy is still widely used. Yet, as many companies are discovering, it is becoming increasingly difficult to compete in today's marketplace by using this strategy.
There are many problems with this form of sequential test development. One of the biggest is that the process practically guarantees your product release date will slip, the project will come in above budget, and corners will be cut that will ultimately jeopardize product quality.
The target release date becomes difficult to meet because the development time allocated for the project is often exceeded, which then shortens the time budgeted for test development. As a result, costs increase due to a lack of time to research alternative instrumentation and measurements for performing the tests beyond those specified by R&D, which often uses very expensive, high-precision instruments during design verification and validation. Additionally, there is often little-to-no time for evaluating the potential reuse of test systems from previous projects, and production test times are rarely reduced due to compressed time schedules.
Finally, quality control can be compromised because of the pressure to stay on schedule and under budget. This impact on quality control can manifest itself in the form of tests that are omitted in the absence of specific instruments, test limits that are eased to avoid low first-pass yield rates, and perhaps the most dangerous of all, a test engineer's lack of understanding of the actual design of the product under test which affects his or her ability to ensure the product is being tested thoroughly.
Full article below:
