06-08-2021 10:27 AM - edited 11-23-2022 01:54 AM
Debugging: (depending on what you want to do)
Exclude dependent packed libraries: (Always enabled!)
Exclude dependent shared libraries: (Always disabled!)
Use Pre-/Post Build Actions to optimize your build
DQMH Module's (generic):
- Move Tester inside of the Library
- Set main.vi public (easier to debug)
Call (non PPL) DQMH from PPL DQMH modules
Obtain Request Events.vi
For all GUI-DQMH modules "Obtain Broadcast Events.vi and Obtain Request Events.vi) must be extended. The VI searches via "VI server" the instance with the valid UserEvent registrations).
TestStand error / stop module integration:
- generate an additional vi to receive the desired events under TestStand (running in a TS-thread)
Add LVLIBP-search path to your Application.ini file (TestStand and normal applications)
Lessons learned:
Main Application settings
If you receive "Error 1003 occurred at File XXX.lvlib:Start Module.vi" you can try the following setting:
In case of strange crashes, recompile the PPL with the MGI Solution Explorer!
=> Still under construction... please wait for updates! 😉
Have FUN with PPL!
Claude
06-09-2021 03:42 AM
Updated and extended...
06-10-2021 06:22 AM
Updated (Pre-Postbuild / Application settings)
07-08-2021 09:18 AM
Added Main application settings
02-22-2022 08:52 AM
HI , THIS HELPS A LOT. THKS !
I GOT A QUESTION:
The picture is not clear enough.Could u show me where i can find the vi(the valid UserEvent registrations)?
Thanks!
02-22-2022 10:00 AM - edited 02-22-2022 10:04 AM
These VIs are only needed if you mix PPL and non-PPL event/broadcast registrations of the same library.
1) Insert the Helper_BroadAndRequest.vim in the "Obtain Request Events.vi" and "Obtain Broadcast Events.vi" in the false case.
2) Make the Wrapper_Obtain Broadcast.vi and Wrapper_Obtain Request.vi static in Memory
=> Replace "Obtain Request events.vi "Obtain Broadcast Events.vi" in the Main.vi of your DQMH module
Well, it sound a littlebit complicated and strange. But something magical happens with these little VIs. Try it and let me know! 😉
=> These little changes allow you to register events of already started PPL modules in non PPL modules.
=> Hint: all Helper_xxx.vi can be stored outside of the DQMH module. The Wrapper_xxx.vi are members of the DQMH modules
Cheers and have fun
Claude
12-05-2022 09:02 AM - edited 12-05-2022 09:05 AM
added "Never, ever use Error Rings and XNodes!" because of the learnings from Darren Nattinger
=> Thanks for sharing!
https://www.youtube.com/watch?v=HKcEYkksW_o&ab_channel=GDevConNA
