How to get the module name to appear in the Stop Module tester messages
When creating a module from one of the two default templates, the tester will use the module's specified name in the three instances of stop messages that are logged in the tester VI. When creating a model from my custom template, I do not get this result. What's the deal?
Here you can see in a module based on my own template, "test panel" is used for the module name, but this is not the name given to the module.
Whereas, "Module 3" (the name given to the module when it was created) is used when building a module from the Singleton template.
_____________
Creator of the BundleMagic plugin for LabVIEW!
(841 Views)
Can you paste the contents of the meta data XML file for your template as a reply to this thread? You can find this XML file on your machine in this location:
[LabVIEW Data]\DQMH Module Templates\MetaData\{your template name}.xml
(806 Views)
