How to generate ppls to avoid libraries dependencies of Delacor objects?
Hello
I developed a project with 6 DQMH modules and I use it in Teststand. In my pc works correctly but when I share the secuence with other members they told me the labview step has errors due missing depedencies. It can be fixed installing labview and DQMH in the computer but there are some computers where I can't install labview. I read a solution is to send the DQMH objects in a PPL https://www.studiobods.com/en/niweek2018-ts1043/  but when I open a main.vi of a module I receive a error about the vi couldn't compile the code and the subvi of enqueue is not found. Any solution?
(619 Views)
Accepted by topic author Alfredo_VM
Can you please change the access scope of the "Enqueue" VIs from Public to Private, rebuild your PPL and try again:
Matthias Baudot | Software Architect | Founder at STUDIO BODs | DQMH® Consortium Board Member
STUDIO BODs     BLT for LabVIEW     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     GCentral Sponsor
 Check out my LabVIEW presentations and videos!
(592 Views)
Thanks. It worked correctly
(553 Views)
